Date/Time: Fri, 14 Mar 2025 12:37:53 +0000
Cross Hair into Tool bar
View Count: 107
[2025-02-06 23:31:17]
User837393 - Posts: 143
I have no issues in adding lines, rays and various tools into the tool bar, but what about the cross hair.
Under what name the cross hair is listed into the Available Control Bar Command, under Customize Control Bar.
[2025-02-06 23:48:10]
User719512 - Posts: 301
Tools >> Chart Values Tool?
[2025-02-06 23:54:30]
Not exactly what I'm asking, but I would like to add it in the tool bar.
[2025-02-07 00:35:18]
Sorry if that is not what you were looking for, but that's how I add what I consider the "crosshair" to my Control Bar.
Sure you'll find what you're looking for in one of the sub items in there...
[2025-02-07 00:35:23]
John - SC Support - Posts: 38653
It's named "Chart Values/Crosshair". Under the Control Bar options it is listed as "Chart Values Tool".
