Date/Time: Fri, 14 Mar 2025 12:29:12 +0000
Font adjustement
View Count: 122
[2025-02-06 20:51:24] |
User837393 - Posts: 143 |
Ref : https://www.sierrachart.com/image.php?Image=1738874690909.png Hello, I would like to adjust the font on : Green connection status bar The price axis The time axis; and the labeling of the chartbook I know that this is in the Graphic Setting - Global Setting - Font, but I can seem to find which one of the option it is. Date Time Of Last Edit: 2025-02-06 20:51:35
[2025-02-06 21:14:41] |
John - SC Support - Posts: 38653 |
For each item refer to the appropriate Font item setting referenced after it. Green Connection Bar (Status Bar): Control Collection Non Button Text Controls Price Axis, Time Axis, Labeling: Chart Text Refer to the information starting at the following link: Graphics Settings: Fonts and Text Appearance Note that we are not certain what you are referring to in terms of "Labeling". So if the "Chart Text" does not affect what you want then we would need to know the exact item you are referencing. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
