Date/Time: Fri, 14 Mar 2025 12:39:08 +0000
Save graphics settings for export
View Count: 106
[2025-02-06 19:18:11]
User993067 - Posts: 174
If I save a chartbook to usb drive for use on another computer, how do I also export the graphics settings that are saved on original computer?
[2025-02-06 19:47:53]
John - SC Support - Posts: 38653
The Graphics Settings, along with most of the Global Settings for the system are stored in the file named "Sierra4.config". This file is located in the main Sierra Chart installation folder. You can copy this between systems to have the same global settings.
But, if you just want the chartbook and don't want to deal with the global settings, then you should change each chart in the Chartbook to use their own Graphics Settings instead of using the Global Graphics Settings. Doing this will allow you to keep the graphics settings for the charts the way you want when you move the charts between systems. Refer to the following:
Graphics Settings: Using Different Color and Graphics Settings for Specific Charts
And keep in mind there are options to copy the Global Graphics Settings to the Chart Graphics Settings. Refer to the following:
Graphics Settings: Copy from Global (Chart >> Graphics Settings - Chart)
