Date/Time: Fri, 14 Mar 2025 12:30:34 +0000
Number bar study dysfunctions following the 2737 sierra update.
View Count: 84
[2025-02-06 15:27:40] |
User410102 - Posts: 3 |
I am using windows 11 on parallels desktop and until now it has always worked perfectly. Following the 2737 sierra update , my number bar study charts disappeared and I have been told by Sierra_Chart Engineering to run the ARM 64 version of Sierra. Which I did and the number bar study chart re-appeared but the custom study from a third party disappeared. Will I always have to run the Sierra ARM 64 version from now on, or the next update of Sierra 64 will fix everything ? Using the ARM 64 version. How can I get back my custom studies from a third party ? Thanks |
