Date/Time: Tue, 22 Apr 2025 02:27:40 +0000
VWAP Calculation Numbers Bars vs Candlesticks
View Count: 110
[2025-02-05 17:20:25] |
tendiemann - Posts: 15 |
Hello, Is there a setting I am missing that is causing VWAP to be ~1pt greater in my candle stick chart vs for numbers bars? Both charts are set to ES. Thank you |
[2025-02-05 19:15:44] |
Sierra_Chart Engineering - Posts: 19290 |
Refer to: Chart Studies: Resolving Study Differences Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
