Date/Time: Tue, 22 Apr 2025 02:24:34 +0000
Locking in change
View Count: 138
[2025-02-05 17:18:33]
User731023 - Posts: 148
I for the life of me can not get changes made to save to Cfg1 as example.
Do not remember it being this hard?
imageBulkowski.jpg / V - Attached On 2025-02-05 17:18:10 UTC - Size: 90.32 KB - 44 views
[2025-02-05 22:45:36]
John - SC Support - Posts: 39395
Whatever configuration you have selected when you make a change will be the configuration that is modified.
You may need to look at the "SaveConfig" page in order to see exactly which configuration is the currently selected one.
Once you make modifications, if you select OK or Apply, then those changes will be applied to that selected configuration.
If you select another configuration button, then the changes are saved to the current configuration and then the new configuration is loaded. For example, if you have TC2 selected and change the color to orange then select the TC3 button, the color of orange is saved to the TC2 configuration and the TC3 configuration as it previously existed is loaded and displayed.
This really has not changed from how it used to work, it's just a little harder to tell which configuration is currently selected. You can change the number of quick configuration buttons are on the tabs with the following setting and the one below it:
Chart Drawing Tools: Number of Quick Configurations for First Tab of Chart Drawing Properties (Global Settings >> Tool Settings >> General >> Shortcut Menu and Properties Window)
