Date/Time: Tue, 22 Apr 2025 02:21:34 +0000
CME Data Problem Interactive Brokers
View Count: 136
[2025-02-05 13:30:56]
User839291 - Posts: 4
Hello There,
I got a problem receving cme data. I was able to receive CME Data now for a month, but now it seems I can't proove as non professional, but I should still be connected to my Interactive Brokers Acc (which is not funded, but it worked out the first mont too), so I hope you can help me solving the problem, and I was logging in to my Acc once a month to prove it.
Best Regards,
Niklas
Date Time Of Last Edit: 2025-02-05 14:54:48
[2025-02-05 14:55:44]
Sierra_Chart Engineering - Posts: 19290
We see you are using Rithmic. Rithmic currently has a problem.
To access historical and streaming market data independent from your Trading service. Follow these instructions.
Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services".
Press "OK"
And then translate the symbols in your Chartbooks in Sierra Chart using this "Edit' menu command:
Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service)
You can then use the data provided by Sierra Chart independent of your trading service.
Date Time Of Last Edit: 2025-02-05 14:55:52
