Date/Time: Fri, 14 Mar 2025 12:33:29 +0000
data
View Count: 150
[2025-02-05 12:32:08]
tickhead - Posts: 13
hello. i am probably a couple of weeks away from funding my account with edge clear. i was hoping i could activate live Eurex and CME Bundle non pro data before then. but i don't have the live funded account for you to verify yet. is there a way to have live data for Eurex and CME before the account is funded and live. thank you
[2025-02-05 16:43:02]
John - SC Support - Posts: 38653
There is no issue with EUREX data. They do not have the requirement of a live account for the non-professional data like the CME Group does. So you can get the EUREX data whenever you like.
But there is not a way to get the CME Group data until you have the funded account to connect to and verify your account.
[2025-02-05 18:01:00]
okay, thanks, that's helpful. i was thinking i might fund the account with $1k or something now. so i can have live and probably simulated data until i get the cash released for the account. would that be enough to activate CME? thank you
[2025-02-05 23:10:38]
If you are referring to $1k for your brokerage account, then that is up to your brokerage. We would think it would be enough for them to create an active account for you, but it is really up to them.
[2025-02-06 10:43:32]
thank you. i will check with them.
separately. is it possible to change the trade window to horizontal and place it above the DOM, rather than on the side. have attached screen shot of idea. thanks
imagemarkuphero-2Kzwytc0gkByXTaZMwMI.png / V - Attached On 2025-02-06 10:42:52 UTC - Size: 398.53 KB - 17 views
[2025-02-06 15:53:55]
Not directly. But most of the functionality for the Trade Window has been replicated in Control Bar options. So you can create a Control Bar that you can put at the top of the Trading DOM that has the Trade Window functionality you are looking for. Refer to the following:
Control Bar
