Date/Time: Wed, 12 Mar 2025 10:57:59 +0000
Unable to see data from previous contracts saved on data folder
View Count: 78
[2025-02-05 03:07:04] |
Rafael - Posts: 16 |
Hello All: I understand that CQG only display data for current contracts from BMF data feed. I was told that, if you accumulate the data month after month, I was going to be able to see data from previous contracts. I have several months of saved intraday data from previous contracts (see picture attached) but I am only able to see intraday data from 11/03/2024 onwards. Can you please helpe me? Thank you
[2025-02-05 05:48:19] |
Sierra_Chart Engineering - Posts: 18750 |
That image does not mean the data actually exists. You need to confirm this through File >> Open Intraday Chart. And check what files you have and the sizes of them.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-02-05 05:48:25
