Date/Time: Thu, 13 Mar 2025 20:36:16 +0000
Data and indicator triggers
View Count: 74
[2025-02-04 17:16:56] |
User714278 - Posts: 1 |
Dear sir/madam, Sometimes my indicator gets triggered and gives out a signal. The problem is that it does not show the same triggers as the past. See the attached files for a visual representation. What could this problem be? I hope to hear from you soon. Kind regards, |
Private File Private File |
[2025-02-04 17:18:31] |
John - SC Support - Posts: 38650 |
We do not have enough information to be able to help. In addition, the images are blurry and we have no idea what we are supposed to be looking for within them. Follow these instructions to get us chart images: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) And we would need specific information on what exactly is occurring and what is not correct and why you think it should be. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
