Date/Time: Thu, 13 Mar 2025 19:55:35 +0000
VWAP
View Count: 100
[2025-02-04 14:25:51] |
User195394 - Posts: 4 |
Hello, On a range bar chart I have integrated VWAP with my own settings. How can I integrate VWAP into the DOM and have the same price as my VWAP which is in my chart? because when I integrate VWAP into the DOM with the same settings as in my chart I do not have the same price for VWAP. Thanking you in advance for your help. Kind regards. |
[2025-02-04 16:35:54] |
John - SC Support - Posts: 38641 |
A Trading DOM does not have the same concept of bars as a typical chart. Therefore, you would need to use the "Study/Price Overlay" to overlay the VVWAP study from the Chart to the Trading DOM. Refer to the following: Study/Price Overlay Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
