Date/Time: Thu, 13 Mar 2025 19:50:03 +0000
How do i get level 2 market data.
View Count: 167
[2025-02-04 13:09:50] |
amari - Posts: 3 |
How do i get level 2 market data? I attached a screenshot of what i am looking for
[2025-02-04 16:33:06] |
John - SC Support - Posts: 38640 |
You are already setup to get the Level 2 Market Depth data for the CME Group. Are you having an issue with this? Or are you wanting to get the U.S. Equities data with Market Depth? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-02-04 16:43:57] |
amari - Posts: 3 |
how do i pull it up? im not sure how to see the data, im specifically looking for the exchange data that the orders are coming from
[2025-02-04 16:58:16] |
For the CME Group data, products are only traded on the one exchange. To see the data similar to what you posted, select "File >> Open Market Depth Window". Refer to the following: File Menu: Open Market Depth Window (File) Just so you are aware, we do not have the breakdown by exchange for the Market Depth data for U.S. Equities. We only have Market Depth data for the NASDAQ exchange. Refer to the following: Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
