Date/Time: Wed, 27 Nov 2024 15:43:05 +0000
TPO Chart
View Count: 905
[2014-09-18 19:39:18] |
TradingMarketProfile - Posts: 120 |
Hello, Is it possible for you to add an option to display on the TPO chart the numbers of TPO above and below the POC Thanks |
[2014-09-18 20:05:57] |
Yes. This can be found in the TPO Chart Text information: http://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html#TextInformation The data is not displayed directly on the chart itself. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-18 20:06:12
[2014-09-18 20:17:39] |
ok thanks
