Date/Time: Thu, 13 Mar 2025 20:31:23 +0000
PERTE DE MES CHARTBOOK
View Count: 90
[2025-02-03 16:06:48] |
User889855 - Posts: 1 |
JE NE RETROUVE PLUS MES CHARTBOOK. ILS SONT EFFACER COMMENT FAIRE POUR RETROUVER L'HISTORIQUE
[2025-02-03 17:47:04] |
John - SC Support - Posts: 38648 |
From Google Translate: I CAN'T FIND MY CHARTBOOKS ANYMORE. THEY'VE BEEN DELETED. HOW CAN I FIND THE HISTORY?
If the Chartbooks are actually gone, then try to recover each chartbook from the backups that Sierra Chart makes for these. Refer to the following: Chartbooks (Workspaces): Accessing a Backup Chartbook File But we are curious as to why your chartbooks would all of a sudden be missing. There is no reason for this to occur from within the Sierra Chart software. Did they get deleted by accident? Are you out of drive space and there was a problem saving the chartbooks so they are now corrupted? Is this a new installation or a change in the installation for some reason? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
