Date/Time: Tue, 22 Apr 2025 02:21:40 +0000
Imbalance stacks extension on other charts and make it as a group
View Count: 152
[2025-02-03 09:49:17]
amansouri1771 - Posts: 3
Hello there
I am trading footprint imbalance stacks. I wanted to know if it is possible to draw these lines as a group? Like in the attached image, there is a 4,4,7,7,3, so Sierra Chart can automatically draw these as a group, not only one of them.
If it is possible, that would be so nice to draw in my footprint chart and also on my main chart, which is a candle-based one.
please look at the screenshots i attached so you can understand better.
imageCleanShot 2025-02-03 at 10.42.58.png / V - Attached On 2025-02-03 09:43:16 UTC - Size: 11.36 KB - 32 views
image3.png / V - Attached On 2025-02-03 09:48:51 UTC - Size: 21.88 KB - 32 views
[2025-02-03 17:29:55]
John - SC Support - Posts: 39395
From what you show, there is not a way to do exactly what you are wanting.
But, the Volume at Price Threshold Alert V2 does have the ability to highlight multiple stacked imbalances and then extend those as a group. Refer to the following:
