Date/Time: Tue, 22 Apr 2025 02:18:38 +0000
[Programming Help] - Question Regarding MGCG25_FUT_CME Chart Data
View Count: 150
[2025-02-03 09:34:37]
User871209 - Posts: 91
I have a question regarding the Symbol MGCG25_FUT_CME (E-Micro Gold Comex Feb 25). For the past five days, the chart appears to show very low volume.
Could this be due to the start of a new month, or is it possible that I have incorrect data?
https://www.sierrachart.com/image.php?Image=17385752243.png
I would appreciate any guidance on this matter.
Thank you.
Regards,
[2025-02-03 09:54:42]
User135243 - Posts: 67
You should use the correct symbols, Gold rolled to April some days ago, use MGCJ25 and everything will be fine :)
[2025-02-03 10:01:30]
Much appreciated for your advice—got it!
I had assumed it would already be in February, I'll try enabling the auto reminder to roll the contract.
Once again, thank you!
