Date/Time: Tue, 22 Apr 2025 02:18:37 +0000
Order fill problem
View Count: 122
[2025-02-03 09:12:19] |
wiivanil - Posts: 12 |
In the chart I have active Show order fills. Everything worked until I’ve lost data connection during an open trade. Now the line that connect the entry doesn’t connect to the exit of the trade but connect to the entry of the next trade. Thank you Ivan |
[2025-02-03 17:27:51] |
Refer to the following (your Daily Profit/Loss should also be wrong from what you state, so the following instructions apply): Help With Daily Profit/Loss Value For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
