Date/Time: Tue, 22 Apr 2025 02:18:41 +0000
Trying to set up my VbP so that the volume col. only shows the most recent 30 Minutes
View Count: 122
[2025-02-02 12:31:20]
User447005 - Posts: 3
I am trying to set up my volume by price bar so that the volume only shows the most recent 30-minute volume.
I have been told to set it up as such:
“One Period at End of Fixed Time Length”
“Time Period for fixed time”
Minutes
and 30
However
When I hit “apply” it reverts back to:
“Based on TPO chart”
...no matter what I do.
How can set this volume column up?
Thank you.
[2025-02-03 17:13:57]
John - SC Support - Posts: 39395
Since you are adding this to a TPO chart, you need to first set the Input on the Volume by Price study for "Set as Independent Volume Profile for TPO Chart" to "Yes", then select "Apply" and then you can set the other parameters as you want. Refer to the following:
Volume By Price Study: Set as Independent Volume Profile for TPO Chart
