Date/Time: Tue, 22 Apr 2025 02:18:38 +0000
Scaling-Idea: Same proportions
View Count: 121
[2025-02-02 10:39:28] |
User551647 - Posts: 25 |
Dear Sierra Chart, I find myself scaling charts and TPO charts a lot after changing windows size. My ideal would be a kind of constant proportion setting where the x and y-scaling stays in a certain ratio, but the canvas just extends or gets smaller when rescaling the window. I understand this as a combination of the currently existing settings of Scale Range: Automatic where the "canvas extends when pulling the window large while the candle sticks or TPOs stay the same as long as now new highs or lows come into the field of view. and the Scale Range: Constant Range + Set X&Y constant relationship, where the x and y proportions are fixed but the canvas does not extend when pulling the windows larger. In essence a constant x&y relationship mode with variable ranges on the x and y axis which are not determined automatically but by user choice. I hope I described this in an understandable way. I believe such a scaling mode would make working with Sierra Charts a lot quicker. Thank you very much and best regards. |
