Date/Time: Tue, 22 Apr 2025 02:18:40 +0000
How to set volume profile data max?
View Count: 120
[2025-02-02 04:51:18] |
User556806 - Posts: 22 |
Hello SC team! I'm trying to use VP for securities but noticed there are volume spikes that don't make sense(e.g. spikes of 15k shares vs regular 500 shares, and the former makes the VP not readable) . - Is there any way I can exclude volumes higher than x amount so they don't show up? TIA! |
[2025-02-03 16:52:55] |
You would have to filter the chart itself. Refer to the following: Chart Settings: Volume Filter (Chart >> Chart Settings >> Data Limiting >> Volume Filter Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
