Date/Time: Tue, 22 Apr 2025 02:21:37 +0000
stock intra-day chart of NVDA
View Count: 170
[2025-02-02 01:50:10] |
User513952 - Posts: 85 |
Hi, In my SC chartbook, the latest chart data of NVDA cannot be properly loaded and it was stuck at 17/5/2024 (refer to the attachment). I have tried to use "Delete and Download" command many times, but it does not work. For all other stocks, the intra-data charts are normal. Please advise. Thanks Charlie |
[2025-02-03 15:40:36] |
Sierra_Chart Engineering - Posts: 19290 |
We see you are using Interactive Brokers data by using that particular symbol. We cannot help with that data. Change the symbol to NVDA to use Sierra Chart provided data. And then use the symbol you are currently using as the Trade and Current Quote Symbol: Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
