Date/Time: Thu, 13 Mar 2025 20:00:01 +0000
Moving Stop Losses Behaves Differently On Sub-Instance
View Count: 164
[2025-02-01 22:43:32] |
User261655 - Posts: 29 |
My primary instance is a DOM only. My sub-instance is a chart. All orders are placed through the DOM. A typical order might be TP1, TP2, TP3 and one stop loss for the whole order. To adjust the stop loss on the DOM/primary instance, I simply click and drag it to the price I want. But on the sub-instance/chart, the stop loss renders as 3 individual stop losses and I have to click and drag each one, rather than have them all tied together. I can't figure out why the sub-instance is doing this. Comparing trade settings has not revealed a solution yet. Any help is appreciated. Thanks! |
[2025-02-03 23:10:06] |
Sierra_Chart Engineering - Posts: 18772 |
There is no solution to this. You need to have submitted the orders from the sub instance to begin with. This is not resolvable. It is just how it is. But what you are doing is unusual with submitting orders from one instance and controlling them from another.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-02-03 23:10:26
