Date/Time: Tue, 22 Apr 2025 02:18:40 +0000
Heat Map_SIM_Service pack 11_No go
View Count: 162
[2025-02-01 14:17:11]
DOM_D - Posts: 2
Hi John / SC,
Thank you for such an incredible product and all your help to all of us.
Just moved to service pack 11, but just for sim training at the moment ES/MES. Have tried everything you've suggested on these boards to others to get my heatmap depth of market to show for SIM trading, but it is a no go.
1- SC Data = In use
2- Make sure data downloaded is long past data requested for sim / replay
3- Market Depth Historical Graph: Market Depth Historical Graph Not Displaying = Check
4- Update to latest rev.
5- Tried with date checked (two days back) and without on Replay = no go
6- Go directly to Date & Time on charts
7- Heatmap is receiving data (open market depth order under charts menu shows it)
*Heatmap works perfectly on live delayed trading.
Notes:
2 DOM's for ES/MES
One DOM receives pulling & stacking. One does not, in SIM mode. Both work perfectly in live delayed.
All other charts work perfectly under SIM
\m/
[2025-02-02 14:48:24]
DOM_D - Posts: 2
All seems to be working as it should now. You may close this. Seems the servers needed time to propagate after the upgrade to service pack 11.
