Date/Time: Tue, 22 Apr 2025 07:40:09 +0000
Interactive Brokers - JPN225.
View Count: 133
[2025-01-31 18:33:38]
G369 - Posts: 23
I contacted Interactive Brokers to ask what the symbol is for JPN225 "CFD" and how to convert it to Sierra Chart and they me to contact you.
How do I use JPN225 CFD with Interactive Brokers as backend?
Interactive Brokers have already pointed the finger at you, not surprised there.
Thanks.
regards
N.
[2025-01-31 18:49:45]
John - SC Support - Posts: 39395
Do not ask them what the symbol is for Sierra Chart. Just ask them for the proper symbol for Interactive Brokers for that CFD. They should give you the symbol. Then enter that symbol in Sierra Chart exactly as they gave it to you and it should work.
For what it is worth, you can also look at the symbol information we have for Interactive Brokers at the following link:
Interactive Brokers Symbols: Contract For Difference (CFD) Format
