Date/Time: Tue, 22 Apr 2025 02:21:37 +0000
Is It Possible to Download Flex Renko Data?
View Count: 171
[2025-01-31 17:58:34]
User413206 - Posts: 36
My chart is of type Flex Renko. However, when I select Edit -> Export Bar Data to Text File, I only see the OHLC data. I don't see the Renko Open or Renko Close data.
[2025-01-31 18:41:32]
John - SC Support - Posts: 39395
The Renko Open and Renko Close are stored in Subgraphs ID0.SG22 (Renko Open) and ID0.SG23 (Renko Close). Therefore, to get these exported you would need to reference them in another study and then export the Bar and Study data.
The easiest way to do this is to use the "Study Subgraphs Reference" study, as it allows for two studies to be referenced. Put in the Renko Open and Renko Close subgraphs in that study and hide the study. Then select "Edit >> Export Bar and Study Data to Text File" and you will have the information in there.
[2025-01-31 22:01:06]
Feedback: If I hide the study, the Renko data doesn't show in the downloaded file. However, if I unhide the study, then they appear in the text file.
Date Time Of Last Edit: 2025-02-03 19:40:40
[2025-02-03 15:51:50]
Sorry, yes that would be correct. So you would need to display the study when you are exporting the data.
