Date/Time: Tue, 22 Apr 2025 07:45:53 +0000
Question on Tick Size
View Count: 200
[2025-01-31 17:35:19]
User141573 - Posts: 1
Thanks for your reply. As can be seen in the picture attached, I have tick size = 0.25 in the chart settings, but here in DOM they are 0.5 ticks apart.
How can I get 0.25 tick size in DOM? Please advise.
Thanks.
imageScreenshot 2025-01-30 182404.png / V - Attached On 2025-01-31 17:35:15 UTC - Size: 164.04 KB - 27 views
[2025-01-31 17:38:32]
John - SC Support - Posts: 39395
We assume you are referring to the scale, as the Market Depth data is all showing at every 0.25 as expected.
You can set the option for "Scale Increment" to "0.25" to force the scale to display in that increment. Refer to the following:
Chart Scale and Scale Adjusting: Scale Increment (Scale Settings)
But keep in mind there is still going to be a minimum width that needs to be maintained, so if you have a very wide range, then it may not display every 0.25 increment.
