Date/Time: Tue, 22 Apr 2025 07:27:50 +0000
Indicator for implied volatility of options
View Count: 200
[2025-01-31 13:49:32]
User437588 - Posts: 69
Hello
is there an indicator that calculates the implied volatility of options? With min and max daily vola for ES and NQ.
These are the calculated max and min vola marks from 30.01.25.
Thank you for your support
image01.JPG / V - Attached On 2025-01-31 13:49:14 UTC - Size: 332.61 KB - 48 views
[2025-01-31 16:33:50]
John - SC Support - Posts: 39395
There is nothing specific in Sierra Chart with regards to determining values specific to Options. All of the studies we have can be applied to most any chart (with some exceptions of needing to be an Intraday or Daily chart).
But given your reference to the daily Min and Max for the ES, we wonder if you are just looking for the following study that can be applied to an Options chart:
High/Low for Time Period - Extended
