Date/Time: Tue, 22 Apr 2025 07:08:35 +0000
Data folder size
View Count: 107
[2025-01-31 07:42:44] |
User895691 - Posts: 7 |
Hello team, I use intraday charts for 3-4 futures instruments and my layout is very simple with 2-3 moving averages and 1-2 additional simple indicators. I do not need more than last 5-10 days on intraday data for continuity purposes. I just checked my Sierra Chart folder in my C drive and see that folders named Data has 32GB size. All other folders are negligible in size. What changes can I make to keep this folder size reasonable to my needs? I am on teton services. Thank you |
[2025-01-31 16:15:14] |
Refer to: Chart Data and Chart Data Files: Cleaning Up Old and Unused Symbols for Efficiency For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
