Date/Time: Tue, 22 Apr 2025 07:45:53 +0000
TAL no Activity report
View Count: 116
[2025-01-31 01:11:25] |
User190629 - Posts: 12 |
I onkly started with live trading 3 days ago. After initial problems it is working very well and I like the system. However I'm unable to track my trades. In TAL under Activity Report it is all empty "0" What is the best way to see: - to see a list of the individual trades ideally with entry time entry rate - same with trade exits - and of course the result of each trade by point and value Thanks for your assistance |
[2025-01-31 15:51:26] |
You need to adjust the filters for the Trade Activity Log so that it will show you what you want. Refer to the following: Trade Activity Log: Common Instructions to Set Trade Activity Log Display Settings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
