Date/Time: Tue, 22 Apr 2025 07:16:53 +0000
[Programming Help] - Help with sc.GetStudySummaryCellAsString() Function
View Count: 121
[2025-01-30 20:01:29] |
User716694 - Posts: 1 |
I'm trying to export several study cells using this function to a CSV file, but am initially just trying to get the cell values to show up in my log file. I have gone through several iterations using AI, but keep getting sent in circles when it comes to coding this in ACSIL/C++. I have several studies that I'm trying to reference, screenshot attached. I have mapped out each study's ID (in the Study Summary window), row ID and cell ID. When I run the following, I keep getting "0" values, even for the common cells like "Last". // Begin Code #include "sierrachart.h" SCDLLName("Export Study Summary Cells to CSV"); SCSFExport scsf_ExportStudySummaryCellValue(SCStudyInterfaceRef sc) { if (sc.Index == 0) { sc.GraphName = "Export Study Summary Cells to CSV"; sc.AutoLoop = 0; // No auto-loop needed sc.FreeDLL = 0; // Keep the DLL loaded sc.HideStudy = 1; // Hide the study (does not display on the chart) return; } // Define variables SCString StudySummaryCellValue; int RowID = 8; // Adjust this to the correct row index (e.g., 0 for the first row) int CellID = 4; // Adjust this to the correct column index (e.g., Last Price, Volume, etc.) // Correct function call with CellID, RowID SCString CellValue; sc.GetStudySummaryCellAsString(CellID, RowID, CellValue); //sc.GetStudySummaryCellAsDouble(CellID, RowID, StudySummaryCellValue); // Log the value if successfully retrieved SCString logMessage; logMessage.Format("Study Summary Cell Value (RowID: %d, CellValue: %d): %f", RowID, CellID, CellValue); sc.AddMessageToLog(logMessage, 0); } // End Code Any help is appreciated! |
![]() Attachment Deleted. |
[2025-01-31 06:23:38] |
Sierra_Chart Engineering - Posts: 19293 |
We have always been very suspicious of this concept of artificial intelligence. We do not believe it actually exists. Anyway, the problem is this: logMessage.Format("Study Summary Cell Value (RowID: %d, CellValue: %d): %f",
RowID, CellID, CellValue); Needs to be: logMessage.Format("Study Summary Cell Value (RowID: %d, CellValue: %d): %s",
RowID, CellID, CellValue); Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
