Date/Time: Tue, 22 Apr 2025 06:59:46 +0000
Price offset on entry
View Count: 109
[2025-01-30 19:37:50] |
Soso - Posts: 1 |
Hi, i am using trading system based on on alert condition, this is my entry =CROSSFROMBELOW(ID10.SG1,ID14.SG1) how do i offset entry to 20 ticks.
[2025-01-30 20:11:36] |
If you are asking how to have the entry when there is a cross from below of ID10.SG1 crossing the value of ID14.SG1 + 20 ticks, then you would have to do this by doing the following: - Add a "Study Subgraph Add" study to the chart and have it reference ID14.SG1 and add the equivalent of 20 ticks in the "Amount to Add" for that chart. - Setup the CROSSFROMBELOW to reference the "Study Subgraph Add" instead of ID14.SG1, so your formula would look like the following: =CROSSFROMBELOW(ID10.SG1, ID15.SG1) Where ID15 is the "Study Subgraph Add" study and SG1 is the subgraph of the Study Subgraph Add study. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
