Date/Time: Fri, 14 Mar 2025 12:23:31 +0000
VOL COLOR
View Count: 89
[2025-01-30 19:03:56]
User645382 - Posts: 1
CAN YOU HELP WITH THE VOL COLOR TRIED ALL KINDS OF COMBNATIONS TO GET THE VOL RED & GREEN VOL BARS AS SHOWN IN TUTORIAL VOL
imageCapture.JPG / V - Attached On 2025-01-30 19:03:50 UTC - Size: 269.44 KB - 27 views
[2025-01-30 19:09:11]
John - SC Support - Posts: 38653
Make sure the Input for "Bid Volume and Ask Volume Coloring" is set to what you want. By default this is set to "Separate Bid/Ask Volume Coloring". Refer to the following:
Volume By Price Study: Bid Volume and Ask Volume Coloring Method
Then those colors are set with the "Bid Volume and Ask Volume Colors (SG6)" subgraph. Refer to the following:
Volume By Price Study: Bid Volume and Ask Volume Colors (SG6)
And finally, you need to make sure that the bars are wide enough that you can actually view the data properly. To do this, you need to adjust the "Ticks per Volume Bar". Refer to the following:
Volume By Price Study: Ticks Per Volume Bar
