Date/Time: Fri, 14 Mar 2025 12:26:14 +0000
Help converting this files please
View Count: 83
[2025-01-30 18:08:28]
User389125 - Posts: 1
2025-01-30 18:04:35.110 | The Chartbook file is not compatible. Contact Sierra Chart support for help with converting it. File: C:\SierraChart\Data\G7FXFOUNDATIONDOMCHARTBOOK-200330-085855.Cht *
2025-01-30 18:04:57.870 | The Chartbook file is not compatible. Contact Sierra Chart support for help with converting it. File: C:\SierraChart\Data\G7FXPROFOOTPRINTCHARTBOOK-200409-002540.Cht *
[2025-01-30 18:18:34]
John - SC Support - Posts: 38653
You need to contact G7FX for updated chartbooks.
