Date/Time: Fri, 14 Mar 2025 12:24:53 +0000
Sync Trade Chart to DOM Chart
View Count: 84
[2025-01-30 17:08:29] |
User590331 - Posts: 2 |
Hello, How can I sync my detached Trade Chart to my DOM Chart so that when I update the quantity on my Trade Chart, it also updates on the DOM Chart? Currently, the quantity does not sync between them. I do not want to attach the Trade Chart to the DOM—just link them. Best |
[2025-01-30 17:56:01] |
John - SC Support - Posts: 38653 |
Each chart has its own Trade Window. So if you have a Chart and a Trading DOM both open, each will have their own Trade Window with their own settings for each trade window. You can link the Trade Window between charts, so any change made to one Trade Window will update the other one. This will keep the quantities in sync like you are asking, but it will also update any other information in the Trade Window, so make sure it is what you want to do. Refer to the following: Chart Settings: Chart Linking >> Trade Window (Chart >> Chart Settings >> Linking menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
