Date/Time: Fri, 14 Mar 2025 12:27:46 +0000
How to Indicate Open and Close on VbP Study
View Count: 79
[2025-01-30 16:52:31]
User708541 - Posts: 112
I have a 1 hr chart with Daily VbP study, with no candlesticks, only the VbP study by itself.
Is there a way I can have some marker, or similar, indicating where the day opened and closed - like is possible with TPO study?
[2025-01-30 17:32:13]
John - SC Support - Posts: 38653
The Volume by Price does not take into account time, so there is no way to have a specific marker in the study that denotes the Open and Close. But you can add any number of studies that give you the Open and Close price and have that displayed on the chart.
Depending on how you want to see the information, look at the following two options (there are others you could use as well):
High/Low for Time Period - Extended
Previous/Period OHLC-Variable Period
