Date/Time: Fri, 14 Mar 2025 12:26:14 +0000
Unable to get Market Depth Historical Graph.
View Count: 87
[2025-01-30 16:40:08]
User495424 - Posts: 7
I am unable to get Market Depth Historical Graph for GBPJPY (Whether that be Spot or Futures). I have been playing around with this on F6 Studies but have had no good luck. I have managed to get it for ES chart but not for GBPJPY chart. Please help me on this as I would like to get Liquidity lines using market orders from the DOM to understand where most liquidity is and where price is more likely to go next and reverse from. I have pictures which I will send over too you now. I hope to hear from you soon. thank you.
imageScreenshot (8).png / V - Attached On 2025-01-30 16:39:12 UTC - Size: 135.49 KB - 25 views
imageScreenshot (7).png / V - Attached On 2025-01-30 16:39:24 UTC - Size: 135.21 KB - 22 views
imageScreenshot (9).png / V - Attached On 2025-01-30 16:39:30 UTC - Size: 174.59 KB - 19 views
[2025-01-30 17:04:06]
John - SC Support - Posts: 38653
Our data feed for FOREX does not include Market Depth data, so what you are seeing is correct.
[2025-01-30 17:28:50]
It works for GBPUSD. Is there any way I can make it work for GJ? Will it it work for Gold? (spot or futures?)
[2025-01-30 18:02:07]
It can't work for GBPUSD, as we do not have Market Depth for that instrument. Are you getting that data from another source? Or is it a different symbol from what you are stating?
We do not know the instrument "GJ". What exchange is this from?
We do have Market Depth data for Gold Futures traded on the CME Group. We have Market Depth data for all the data from the CME Group. You are setup to get the data from the CME and COMEX exchanges of the CME Group including Market Depth at this time.
