Date/Time: Tue, 22 Apr 2025 06:46:00 +0000
Footprint settings
View Count: 210
[2025-01-30 15:03:52] |
User977892 - Posts: 8 |
I can't correctly see my footprint. The numbers near the candlestick are covered by them, and they disappear after a couple of pixels starting to te center of the candlestick.this is what i see : https://www.sierrachart.com/image.php?Image=1738249061663.png If there is any video that can help me to adjust it, i would be grateful. Since i see some video on the internet that unfortunately don't have helped me. |
[2025-01-30 16:51:39] |
You need to use Chart Graphics Settings and set the candlestick width to a very narrow percentage (start at 10). Refer to the following: Graphics Settings: Candlestick Width % (Global Settings >> Graphics Settings >> Other) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-01-30 17:35:41] |
Thank you. One last thing. In the first column there aren't numbers in every price levels. Imagine : https://www.sierrachart.com/image.php?Image=1738258436181.png
[2025-01-30 18:03:42] |
It looks like you have the "Bid/Ask Volume Text Threshold" set to a non-zero value. Refer to the following: Numbers Bars: Bid/Ask Volume Text Threshold For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-01-30 18:41:28] |
I checked and its already put on zero. What else could it be?
[2025-01-30 20:43:36] |
Please get us that chart by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
