Date/Time: Fri, 14 Mar 2025 12:22:09 +0000
Graphic Settings in Instances
View Count: 123
[2025-01-30 14:16:03]
novaxt123 - Posts: 54
I am working with several instances. Now I would like to change some colors in the graphic settings and then use these changes in the other instances.
Which file do I have to copy into the instances that contain the graphic settings? Is it Sierra4.config?
[2025-01-30 16:37:30]
John - SC Support - Posts: 38653
Sierra4.config contains the global settings, which includes the Global Graphics Settings. So this is the file to copy to the other instances for what you want.
