Date/Time: Fri, 14 Mar 2025 12:23:32 +0000
Changing the Size of Scales
View Count: 109
[2025-01-30 14:03:33] |
User264564 - Posts: 10 |
Hello, How do i get these scales on the x - and y-axis bigger? See Screenshot attached. best, Manuel |
[2025-01-30 16:36:15] |
John - SC Support - Posts: 38653 |
The items you are pointing to are controlled by the "Chart Text" font. Refer to the following: Graphics Settings: Chart Text - (current font name) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
