Date/Time: Thu, 17 Sep 2026 01:03:14 +0000
Numbers Bars (Ask Vol Bid Vol Difference above a certain value)
View Count: 1312
[2025-01-30 12:30:17]
User753987 - Posts: 1
Hi everyone, i'm almost certain, this has been asked before. I searched the forum but i havent found my answer.
when i set in numbers bars, "column 3 numbers bars text" to "Bid Vol x Ask Vol"
AND
"Bid/Ask Volume Threshold (In 94)" to "10" only volumes above 10 or -10 will be visible (See attached image 1 bidvolxaskvol).
The description says: This Input setting only applies when the Column # Numbers Bars Text Input is set to Bid Volume x Ask Volume. Only Bid Volume numbers or Ask Volume numbers that exceed this number will be displayed. The default value is 0 which means all volume values are displayed.
NOW my question :)
When "column 3 numbers bars text" is set to "Ask Vol Bid Vol Difference", is there a way (in numbers bars or another way) to only see values above a certain value (10)? Pls see image 2 askvolbidvoldifference. I want it like this but only with values above 10. Is there a way?
Thx a lot
image1 bidvolxaskvol.png / V - Attached On 2025-01-30 12:21:25 UTC - Size: 71.4 KB - 247 views
image2 askvolbidvoldifference.png / V - Attached On 2025-01-30 12:21:40 UTC - Size: 75.21 KB - 210 views
[2025-01-30 15:44:47]
John - SC Support - Posts: 47917
This has been set as a Feature Request. We can not say when we would get to any particular request.
[2025-03-14 17:59:20]
mastadom - Posts: 26
+1. Would love this feature as well
