Date/Time: Fri, 14 Mar 2025 12:27:46 +0000
trade message pop up
View Count: 151
[2025-01-29 23:48:29]
User531621 - Posts: 107
Hi folks, How do i disable the message box pop up when i enter and exit a trade. Thank you so much for all of your help!
[2025-01-30 04:31:53]
Sierra_Chart Engineering - Posts: 18778
First, it is important to look at the message and understand why it is occurring to begin with. To prevent the log from opening, refer to:
Message Log: Preventing Message Log from Automatically Opening
[2025-01-30 15:07:58]
John - SC Support - Posts: 38653
If you are referring to Confirmations, then refer to the following:
Basic Trading and the Trade Window: Main/C >> Menu >> Order Confirmations (chart specific)
[2025-01-30 16:35:17]
Hello! Its not the message log. Its a pop up when i enter and exit a trade. It says:
My acct number - bought 1
the symbol and the price
Does the same when i exit.
Please advise, thank you so much
[2025-01-30 17:03:02]
Those are the Confirmations. Refer to our response in post #3.
