Date/Time: Tue, 22 Apr 2025 06:51:32 +0000
Drawable Volume Profile
View Count: 180
[2025-01-29 18:50:33]
VenoYoTiK - Posts: 19
how is it possible to set the new settings of a drawable volume profile to either standard or so that I can load the settings?
Because I change the settings and I can`t get it to a new drawn profile.
https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=114422
Thank you very much an have a nice day! :)
imageScreenshot 2025-01-29 at 19.45.06.png / V - Attached On 2025-01-29 18:50:08 UTC - Size: 950.74 KB - 107 views
[2025-01-29 18:58:44]
User431178 - Posts: 654
You need to save it as a tool config, link to instructions below.
Volume By Price Study: Step by Step Instructions to Configure the Draw Volume Profile Tool
[2025-01-31 10:51:18]
Thank you very much, this was very helpful :)
