Date/Time: Mon, 15 Dec 2025 09:10:58 +0000
Need New Study -- Vertical Line on Alert
View Count: 397
[2025-01-29 18:18:30]
User360283 - Posts: 524
I currently have the study Color Bar on Alert driven from the Zig Zag study.
It works OK but I would like to have a Vertical Line drawn in addition to the color bar
A Need New Study -- Vertical Line on Alert woulds be he best.
Will you implement the new study soon?
If not how can I get the vertical Lines drawn on the alert for now?
[2025-01-29 18:34:58]
John - SC Support - Posts: 43443
You would need a second copy of the "Color Bar Based on Alert Condition" setup the same way as your first one (duplicating the original is the easiest way to do this). Then set the "Color Bar" subgraph Draw Style to "Background" and set the Width to be the size of the line you want and the color. Refer to the following:
Chart Studies: Background (ACSIL: DRAWSTYLE_BACKGROUND)
Chart Studies: Subgraphs Tab >> Line Width
Chart Studies: Subgraphs Tab >> Color
