Date/Time: Fri, 14 Mar 2025 12:26:14 +0000
$SPY: No data feed on Jan 28th 2024 @01:15 PM ET
View Count: 233
[2025-01-29 18:15:05] |
User840964 - Posts: 49 |
Please verify, thanks.
[2025-01-29 18:15:57] |
Jan 29Th 2025, sorry.
Date Time Of Last Edit: 2025-01-29 18:17:18
[2025-01-29 18:31:07] |
John - SC Support - Posts: 38653 |
Everything on our end is fine. We see the data flowing with no issues. Keep in mind, the symbol you should be entering is "SPY-NQTV" (no quotes), since you have the NASDAQ TotalView exchange active. If you are entering just "SPY" (no quotes) then you will get the delayed streaming data from our U.S. Equities Consolidated Tape. You should not be entering the symbol as "$SPY" (no quotes). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-01-29 19:07:56] |
The platform has reloaded data starting from the beginning of the day and now it works fine. Of course I'm using the -NQTV suffix. |
[2025-01-29 19:15:55] |
Sierra_Chart Engineering - Posts: 18778 |
We see no problems with the data feed at that time. It was up and running fine with no interruption.
[2025-01-29 20:31:16] |
Actually there was an interruption. And we apologize for this. The data has been recovered.
