Date/Time: Fri, 14 Mar 2025 12:23:31 +0000
issue with a function in the tool box
View Count: 102
[2025-01-29 16:19:58] |
User531621 - Posts: 107 |
Hello! i cannot use the "erase all non-text drawings" in the tool box. It does not allow me to erase. I have to erase one at a time. Please advise, thank you!
[2025-01-29 17:12:18] |
John - SC Support - Posts: 38653 |
Are your drawings locked?
[2025-01-29 19:17:38] |
HMMM, good question.. i didnt know you could lock them.. not sure if mine are or not, how do i unlock just in case they are? Thank you
[2025-01-29 22:17:55] |
The easiest way to find out is to select "Tools >> Manage Chart Drawings Window". That will bring up a window that lists all the drawings for the active chart. On that page is a column for "Locked" and if a drawing is locked it will state "Locked" in that column for a drawing. The reason we ask this is that having the drawings "Locked" is one reason the drawings would not be removed when you select "Tools >> Erase All Non-Text Drawings". One other possibility is that you have the drawings copied from another chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-01-29 22:54:14] |
Thank you John! The Locked instructions helped...!!!!
