Date/Time: Tue, 22 Apr 2025 06:48:48 +0000
Chart Sync
View Count: 109
[2025-01-29 14:20:50] |
Mitch1840 - Posts: 17 |
Hi, I have Chart of NQ and ES side by side. I want to sync the time axis(Y) sync in both the chart how do I do that ? Currentl, When I in NQ then Y is not moving in ES. How I can have time axis sync in both the charts and focus chart should have X and Y both active. Mitul |
[2025-01-29 16:42:23] |
There are a couple of options depending on how you want to synchronize them. Refer to the following: Chart Drawing Tools: Synchronize Charts (Tools >> Synchronize Charts) Chart Settings: Chart Linking >> Scroll Position (Chart >> Chart Settings >> Linking menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
