Date/Time: Tue, 22 Apr 2025 07:22:13 +0000
how far can daily ES, MES, chart data go back?
View Count: 114
[2025-01-29 14:10:21]
User984103 - Posts: 4
hi,
How far back does the chart data go at the maximum for a paid subscription for the CME MES AND FULL ES CONTRACTS go?
I have already used the chart options to adjust the days and selected the continuous data rollover and updated the symbols in the trial version and it wont go back past 2 mths and i have no idea how to add symbols for the mes and es contracts for earlier expiry dates as there are only the last 3 expiries showing when re-downloading chart data.
thanks
[2025-01-29 16:36:31]
John - SC Support - Posts: 39395
You are limited in how much data you can access while on a trial. Refer to the following:
Sierra Chart Trial Account
The MES data goes back to the launch of the Micro products (May of 2019).
Refer to the following for the general information on historical data:
Sierra Chart Historical Data Service: What is Included
