Date/Time: Fri, 14 Mar 2025 12:23:31 +0000
Micro charts not working on replay
View Count: 103
[2025-01-29 12:39:22]
User572037 - Posts: 21
Trying to use replay function, for some reason the micro charts are loading properly.
Not sure if they are loading correctly, & are just lost in the abyss, can't find on price level, also can't scroll to the left of right.
[2025-01-29 16:05:25]
John - SC Support - Posts: 38653
We need more specific information on exactly what is occurring.
[2025-01-29 16:25:11]
I am trying to use the replay function.
I have various lower time frame charts, usually whenever I use the replay function I have no problem. But unfortunately now when I try the charts basically load up blank.
I can't tell whether they are loading and that the PA just isn't in the frame, or whether it is not loading at all.
If I scroll down to the current price level there is nothing there, if zoom out or change scale, I still can't see anything.
[2025-01-29 17:57:43]
You need to ensure that there is data loaded in each of the charts you are replaying back to the time at which you are starting the replay. Check each chart individually, and if there is not enough data, then you need to get it loaded into the chart first.
If the above does not resolve the issue right away, then start by replaying a single chart where you are having an issue. Make sure it has enough data loaded and see what occurs.
