Date/Time: Tue, 22 Apr 2025 06:57:05 +0000
Re-downloading missing trade activity does not restore TransDateTime
View Count: 191
[2025-01-28 22:13:49]
User990275 - Posts: 26
Hello, I accidentally deleted some trade activity and followed the instructions for re-downloading the missing activity upon the next reconnect. The trade activity has been restored and shows in the TAL, but the Account and Period stats are empty. I believe this is occurring b/c the missing fills that were downloaded are all missing the TransDateTime column.
I would like the TAL to show me accurate Account and Period stats for the restored trade activity. Thank you!
imageScreenshot 2025-01-28 140856.jpg / V - Attached On 2025-01-28 22:12:55 UTC - Size: 292.91 KB - 34 views
[2025-01-28 22:21:27]
I took a closer look and it's also missing OrderType, Filled Quantity, Exchange Order ID, Client Order ID. This is with Rithmic data connection.
Date Time Of Last Edit: 2025-01-28 22:23:46
[2025-01-28 22:35:26]
John - SC Support - Posts: 39395
We are surprised you were able to get anything from Rithmic. Typically they do not keep the order fills for very long.
You would need to edit those entries to enter the appropriate information for them. Select one of the order fills and select "Edit >> Edit Trade Activity Entry". Refer to the following:
Trade Activity Log: Trade Activity Data Editing Menu Commands (Trade >> Trade Activity Log)
[2025-01-29 00:03:27]
Sierra_Chart Engineering - Posts: 19293
This is not required:
TransDateTime
[2025-01-29 00:11:08]
Which fields are required for the stats to calculate correctly?
Are these not being picked up correctly by Sierra? Or is Rithmic not returning the data?
Given that timestamp, direction, and entry exit price are all present, this is a Sierra issue.
External journals have no issue calculating the stats feom the available fields.
[2025-01-31 05:39:00]
The date-time, the fill price, the quantity, the side, the account, the symbol.
These are not necessary:
Check to make sure this is not enabled:
Trade Activity Log: Edit >> Filter Initial Fills Part of Existing Position
Make sure you are seeing the fills on the Trade Activity tab of the Trade Activity Log.
And make sure this is disabled:
Edit >> Disable Statistics, Trades, Period Tabs
Date Time Of Last Edit: 2025-01-31 06:15:46
[2025-01-31 06:08:51]
Ah, thank you! Disabling Filter Initial Fills Part of Existing Position did the trick.
Looking at the docs, it looks like the external service does not report the position quantity so this setting cannot be enabled or all the fills will be filtered.
Perhaps this can be added to the docs for restoring Missing Trade Activity from an external service.
[2025-01-31 06:21:27]
Documentation has been updated.
