Date/Time: Tue, 22 Apr 2025 07:57:12 +0000
my trading montage is displaying random number and my show fills are painting 2 arrows
View Count: 207
[2025-01-28 18:40:56]
User856350 - Posts: 34
my montage is printing random numbers when i enter a trade and painting 2 arrows facing each other on entry and exit but only for 1 of my accounts how can i fix this?
[2025-01-28 21:38:17]
John - SC Support - Posts: 39395
We really do not know what you mean. Please get us an image by following these instructions:
[2025-01-29 03:04:07]
https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=114385
attachmentChartbook3. for support.Cht - Attached On 2025-01-29 03:01:46 UTC - Size: 14.36 KB - 113 views
[2025-01-29 03:42:24]
Sierra_Chart Engineering - Posts: 19300
Are you referring to order fills displayed on the chart? We cannot tell this by getting a Chartbook.
What we need is an image of the chart. Instructions:
[2025-01-29 13:57:16]
https://www.sierrachart.com/image.php?Image=1738158925667.png
i hope this helps as you can see the double arrows facing each other and from the other image the -54P loss... that was supposed to be 1 trade for 2 contracts and a 5 point stop.
[2025-01-29 14:17:22]
This is an issue with the order fills loaded in the chart. Refer to:
Chart Trading and the Chart DOM: Accurate Entry/Exit State, Fill Matching and Position Quantities
